#1 | ||||
![]() Join Date: Feb 2007
Hi all, I'm a newbie here. I found this site awhile ago when I was having issues with my DRL. Thanks to this sight we were able to fix it without taking it in, so thanks for that
. Now the problem is the Service Engine Soon light, it stays on all the time. It's a 2003 Vue V-6 AWD with 37,000 miles. It started doing this a few weeks ago when the temps dropped to 10 below 0. We have unplugged the battery to see if it would reset and it did for a week and now it's back on again. Help, please![]()
#2 | ||||
I don't own a vue but I have had that problem with my 2002 sl and my wife's 2000 oldsmobile alero wha our problem was the gas cap wasn't tight all the way on it but when we tightened it up the light eventually wen't away so try that
... 2002 SL1 GO BIG OR GO HOME
#3 | |||||
![]() Join Date: Nov 2002
#4 | ||||
Assuming you are out of warranty....
Take it to parts store like autozone or advance auto parts... They should be able to look up the codes for you, for free. Write the actual codes(not the description) and post them here. Hope that gets you started to tackle the error codes.
#5 | ||||
Welcome to the Board.
We need codes to help you out. The SES light being on covers a lot of ground. ... A lousy day in paradise is still a day in paradise.
#6 | ||||
![]() Join Date: Aug 2006
1998 SW2
is it a solid light or a blinking light, it makes a difference. and having someone pull the codes is kind of the entire reason for having them, makes it a lot easier to fix the problem.
#7 | ||||
Unfortunaely if it's like mine the generic readers won't be able to read the codes. Mine said "No faults/codes" with the light burning away on two different OBDII readers. Hopefully yours isn't a vehicle specific code.
Good luck Dave ![]() ... Never let facts stand in the way of a good opinion!!
#8 | ||||
![]() Join Date: Dec 2001
2002 VUE 3.0L
My money is on the code being a P0128 (Thermostat TSB).
... 02 VUE Auto AWD-60k-Florida 02 SL2 Manual -65K-cruising in Germany 00 SL2 Auto-85K-aging in Portland, OR 99 SL2 Auto-115K-aging in Portland, OR 91 SL1-Stolen 03, 113K 96 SL1-Totaled 02, 86K
#9 | ||||
![]() Join Date: Oct 2006
When the weather warmed up to above 30 here in boston my SES light went off. I had it coded before it went off and found out on this board what my code meant. I was kind of freaking out beuase I had just dumped money into it and now I was going to have to dump more. but then the light just shut itself off. funny thing is all of us posters with po 128 code with 2003 vue had the same problem with the themostat code thing when the weather had hit fridgid.
| Thread Tools | |
| Display Modes | |
| Service Engine Light and Fog light | singgirl17 | S-Series Tech | 0 | 11-17-2008 08:58 AM |
| When will my service engine light go out? | dst10spr97 | Aura General | 3 | 12-29-2007 11:48 PM |
| service light (not service engine soon) 96sl2 | irondiezl3 | S-Series Tech | 9 | 11-14-2006 06:51 PM |
| engine temp and service engine soon light after CAI install | Nicksl21991 | S-Series Tech | 10 | 11-11-2006 09:47 AM |
| Ignition Module / Engine Coolant Sensor Prob? Service Engine Light, Rough Performins | Brendo613 | S-Series Tech | 14 | 10-19-2005 06:12 AM |
