#1 | ||||
![]() Join Date: Nov 2005
1995 SL
1998 SL
This is for the next person that struggles through this repair. It can be done but obtaining a prefilled assembly is still the easiest way to go. Anyway, assuming your are replacing the Master or Slave cylinders (or both) and end up buying separate pieces here are the steps. 1. Get the old assembly out of the car. 2. Separate the hoses and replace the cylinders and hook the hoses back up. You should now have a rebuilt assembly full of air. Now for the 'bleeding'. 3. Fasten the Master and Slave cylinders to something (a 2X4 worked for me). Fasten them about 18 inches apart. The slave cylinder should be pointing straight up. 4. Put it in a vise to hold it. 5. Make sure that the hoses dangle below the cylinders and the cylinders are fairly level with each other. 6. Dismantle the slave cylinder (its easier than you think). The Slave Cylinder consists of 4 parts - the casing, a spring, a plastic plunger and a spiral clip to hold everything together. Just pull the shaft out of the rubber boot and snap the boot off. Use a very small screw driver to pry the end of the clip out of its recess and 'slice' the screwdriver around to spin out the clip. Dont worry about the plunger flying out, there is little or no pressure left from the spring - its too short.7. Now fill the Master cylinder pot with brake fluid and carefully pump the fluid into the line. Keep the the pot filled and pump fluid until your convinced there are no more air bubbles. The fluid will overflow out of the slave cylinder. Put some more in to make doubly sure. 8. Put the spring back in, then the plunger then the spiril clip. To get the clip back in spread it out (carefully) and get one end into the recess. Hold the end in and use the small screwdriver prod clip along. Thats the hardest part. 9. Put the boot back on and the shaft and your done. If you are replacing the Slave cylinder then you can take the original Slave cylinder apart for a little practice. It is not very difficult and worked the first time for me. Just try not to bend the spiral clip.
#2 | ||||
Interesting, this is the first posted method that I would be willing to try. Thanks!!!
... There is nothing more frightening than ignorance in action.
#3 | ||||
mavmav, you must have had an eye on this forum for a while to recognize the value in this contribution.
Thanks a lot! stu
#4 | ||||
can you take pictures?
maybe we'll mail you all our duds and you can rebuild them for fun and profit. ![]()
#5 | ||||
Or try this alternative method:
Buy a new clutch hydraulic assembly from saturn, install it, and be worry free for years and years to come. ... 1996 SC1 1995 SC2
#6 | |||||
... -96 SC2 gets 35 mpg mix city/hw.
#7 | ||||
1995 SL
1998 SL
Thnks Stu. I've been pouring through this site after struggling for a couple of weekends to fix my 95 SL. Its the first real repair that its needed in 10 years. I could not get the finished assembly so had to opt for replacing the cylinders.
Obviously there are many people running into the same problem so I wanted to give something back. This site is a wonderfull find. My intentions where to get the precharged assembly after reading the posts on this site. For those in the US, its cost is $225+ tax up here - about 1/3 more. Buying the cylinders and new lines (thanx Princess Auto) came out about the same. So there is really no money to be saved unless one cylinder only is replaced. Get the precharged assembly instead if you can. One other caveat. My beloved 95SL has the hard to shift problem. The hydraulics, clutch, release bearing and pressure plate I've just replaced. Its still hard to shift. So there are no guarantees. There is something else wrong somewhere.... 1995SL - 165K Kilometers - under extremely rare repair 1998SL - 185K Kilometers - new daily driver
#8 | |||||
http://www.saturnfans.com/forums/showthread.php?t=62121 It seems that various bushing solutions are offered on e-Bay stu
#9 | ||||
1995 SL
1998 SL
I will definately check it out. Thanx.
#10 | ||||
![]() Join Date: Apr 2013
1997 SL1
Especially now that all the "brand new OEM parts only" nazis no longer have anything useful to contribute and even junkyard parts are often rusty and just as bad as the ones folks are trying to replace.
#11 | ||||
![]() Join Date: Jun 2012
1999 SC2
2008 Outlook XR
After reading other threads, I finally came to this one. I had to replace my slave cylinder after blowing it up. I thought I had all the air out of the system. I refused to believe that I would have to buy a whole new system. Thanks Mavmav for the detailed information. Guess what I'm going to be doing on my next day off!!!
#12 | ||||
![]() Join Date: Dec 2012
Hello! I have this problem with the clutch assembly... see if anyone can help.
I was driving here a few days ago, and suddenly (as per usual) my clutch decided to seize (and heres the kicker) but it seized in the DISengaged position... (ie engine running, put in any gear, nothing would happen) So today I tried to install a new slave and sure enough, the old slave had the rod extended fully and we tried to push the rod back in. No good. Once we had it apart from the line though, that slave rod moved back and forth quite freely. Put the new slave in, tried the nightmarish procedure to bleed it, cut the plastic retaining straps (so the rod was extended fully), filled it full... but of course, it wouldnt budge back so there was room to twist the slave cylinder back onto the tranny housing... So! I see that there is a line going from the master to this plate, then a second hose going from this plate to the slave. Is there a valve of some sort in that plate?? I can get the fluid to go to the slave, but it wont go back to the master; explaining the clutch seizing in the DISengaged position... Or should I just fork out more $$ and just get the whole assembly? Thanks!
#13 | ||||
Well, you just did it the hard way without any familiarity with hydraulic systems so why struggle and simply buy the entire master/slave unit with hose and replace the old with new?
Bet you're car has well over 100k miles....................because a clutch is in the future if you have to replace the clutch master/slave unit. ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#14 | |||||
![]() Join Date: Jan 2013
the air was gone !!! ![]()
| Thread Tools | |
| Display Modes | |
| Bleeding slave-clutch repair update. | marko16 | S-Series Tech | 11 | 02-01-2007 12:16 PM |
| Clutch Master/Slave Cylinder | blackeagle1 | S-Series Tech | 5 | 10-22-2006 07:13 PM |
| Thanks for the help...did the clutch master/slave install with your help | uwantanmri | S-Series General | 1 | 03-19-2006 12:37 PM |
| need help tapeing and bleeding clutch slave cyl...... | jcurrieirocz | Miscellaneous Tech | 9 | 11-26-2003 07:41 PM |
| difference between clutch actuator and clutch master/slave cylinder | geartooth94 | S-Series Tech | 3 | 06-10-2003 11:36 AM |
