Old 03-08-2018, 03:23 PM   #1
trainer
trainer is on a distinguished road
Default replacing 95sc2 backup bulbs
need to replace backup bulbs 95sc2 can feel sockets under bumper but cannot really see them,manual says depress tab and rotate counterclockwise 1/8 turn.I need to know where the tab is located to depress,and is it hard to do with finger?
Add to trainer's Reputation
Rate the quality of this post and help trainer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trainer is offline   Reply With Quote
Old 03-08-2018, 09:07 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: replacing 95sc2 backup bulbs
Its been a while, but if I remember correctly, the reverse bulb socket is similar to the brake bulb socket. Remove one of your taillights and familiarize how the brake bulb socket is removed, the reverse bulbs socket should be similar.
Mike
-1991 Turbo SL2 - Gone, but not forgotten.
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 03-09-2018, 07:19 AM   #3
Saturn Night
Once you get the socket connectors out, make sure to wear latex gloves when changing the bulbs. GM used some kind of thick, yellow insulation grease on those bulbs and the oils of your skin actually reduce the life of the new bulb.
Like the connectors, the bulbs will need to be turned slightly to be removed and the new ones installed. You may notice the replacement bulbs have little, metal tabs on the very bottom of them, and they may be offset. This is so the bulb is not installed incorrectly into the connector.
Old 03-09-2018, 10:31 AM   #4
trainer
about bulbs with yellow grease must be talking about never model saturns, got correct replacement bulbs at autozone in a 2 pack and they are just plain small bulbs no yellow grease,have base I think is called bayonet base will see if can remove old bulbs today and see how heir bases look.new bubs have no little metal tabs like you describe
Old 03-09-2018, 10:36 AM   #5
If there's no metal tabs then there's no way for the bulbs to lock into the socket or you got the wrong bulbs.
1156 bulb used for reverse lights and the single circuit light in the taillight: https://media.digikey.com/photos/CML...hotos/1156.jpg
The yellow grease is put on the sockets from the factory, it generally doesn't come with replacement bulbs (never seen it included).
Running cable for backup camera & tapping into reverse lights for backup sensors shaxs Vue General 18 10-19-2016 11:13 AM
changing backup bulbs saturnsctwo S-Series Tech 2 08-20-2011 05:28 PM
Replacing bulbs for a/c console Meridian S-Series Tech 8 09-12-2004 02:35 AM
Replacing Bulbs for A/C Console Meridian How-To Library 1 08-26-2004 08:46 PM
Backup light bulbs beasjd S-Series Tech 1 07-09-2001 09:30 AM
