Old 11-10-2017, 04:08 PM   #1
cpy911
cpy911 has a spectacular aura aboutcpy911 has a spectacular aura aboutcpy911 has a spectacular aura about
1996 SC2
Default Baldwin fuel filter--what are these extra pieces?!
I am getting ready to change the filter in my '96 SC. The filter is the older version that goes in the engine bay area.
I ordered a Baldwin filter and it came in a box with no instructions. The connector that goes to the engine looks ready to snap on. However, on the filter itself there is no connector. There were extra pieces in the box and I have no idea how they orient or where they go. Any thoughts? I don't want to have my car down, so trying to get a plan in place first. Anyone changed the older fuel filters have any clues?
Picture attached.
Thanks!
Add to cpy911's Reputation
Rate the quality of this post and help cpy911 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cpy911 is offline   Reply With Quote
Old 11-10-2017, 05:02 PM   #2
Default Re: Baldwin fuel filter--what are these extra pieces?!
The inlet side of the existing filter should have a slip on connector with 2 tabs sticking out of it pointing towards the fuel pump body. You squeeze the tabs and carefully slide the connector off of the old filter and then onto the new filter. It inserts to the point you hear the latch click over that ring on the inlet tube. Should not need those extra fittings.
What is actually there depends on how bad it has been hacked over time.
Old 11-10-2017, 10:50 PM   #3
ssicarman
ssicarman's Avatar
The two speed nuts are for the fuel filter bracket, they replace the ones currently on the car that may in poor condition.
The larger folding plastic piece is the release tool for the fuel line hold in clips.
The other plastic piece is a fuel line clip.
Add to ssicarman's Reputation
Old 11-10-2017, 10:53 PM   #4
cpy911
1996 SC2
Ahhh. Makes sense! Thanks!
Parts Master fuel filter vs Wix fuel filter AprilSL1 S-Series Tech 21 08-05-2014 08:43 PM
Extra Fuel Line? the_goose84 S-Series Tech 2 08-08-2013 10:35 AM
Extra Capacity with FL-400S Oil Filter KevinVarnes S-Series Tech 14 10-20-2008 11:20 PM
Extra box to air filter housing????? fetchitfido S-Series Tech 38 05-25-2006 05:50 AM
Fuel injector? Fuel filter? Air filter? LoveMySaturn Miscellaneous Tech 13 05-14-2004 09:14 PM
