Old 11-09-2017, 06:59 PM   #1
Thruxtonup
Thruxtonup has a spectacular aura aboutThruxtonup has a spectacular aura aboutThruxtonup has a spectacular aura about
2002 SL1
Default 02 sl1 heat isn't working
Hey all, just recently found the forum.
I have an auto 02 sl1 with 105xxx miles.
I've ran into a strange issue where, it's throwing a constant coolant temp light, no matter where the temp gauge is and will only blow warmish air on the lowest fan setting. Any higher and the air is pretty much the ambient temperature.
Any insight is appreciated!
Add to Thruxtonup's Reputation
Rate the quality of this post and help Thruxtonup reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thruxtonup is offline   Reply With Quote
Old 11-09-2017, 07:37 PM   #2
Chrisohki
Chrisohki is on a distinguished road
1996 SC2
Default Re: 02 sl1 heat isn't working
Have you checked your coolant level yet?
Add to Chrisohki's Reputation
Rate the quality of this post and help Chrisohki reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chrisohki is offline   Reply With Quote
Old 11-09-2017, 07:38 PM   #3
Thruxtonup
2002 SL1
Yes. Completely full
Old 11-09-2017, 08:29 PM   #4
Chrisohki
1996 SC2
Could be the thermostat stuck in open position.
How hot does the gauge get after rubbing for 15/20 mins?
Old 11-09-2017, 08:42 PM   #5
Thruxtonup
2002 SL1
Usually hangs on between 1/4 And 1/2
Old 11-09-2017, 09:13 PM   #6
You may be describing two issues; lack of heat and an errant coolant indicator. If the engine isn't overheating, the coolant indicator may be telling you coolant level is low. Even when coolant level is correct, old cooling systems create slime and other undesirables. I not flushed out and replacing antifreeze, sludge may collect on the float, dropping it lower by weight and triggering the coolant light. A quick test of this is to overfill the container above the fill line by about an inch and see if the light turns off. If it does, the coolant container can be cleaned with hot water and dishwashing powder to remove sludge on the float. Or just overfill and leave it at that. The lack of heat may be related to one of several things; blocked heater core, heater hoses, outlet tube or worn out t-stat. If periodic coolant flushing and replacement isn't done, do so and disconnect the heater hoses to force water into the heater core to flush out any blockage, reversing flow to ensure flow.
Old 11-20-2017, 09:45 PM   #7
Thruxtonup
2002 SL1
I finally had time to flush the core today, and success! I have heat.
Thanks everyone
2003 Vue AC/Heat mixer not working driveguy Vue Tech 1 06-13-2013 09:05 PM
97 Saturn SL2 interior fan to blow heat not working paumcd S-Series Tech 1 11-05-2011 03:07 PM
Heat Not Working In 96 SC1 SickSc1 S-Series Tech 3 12-07-2009 10:42 PM
A/C not working and get low humming noise when turning on the heat. jc123 L-Series General 2 04-12-2006 02:28 PM
2001 L300 AC/Heat Fan Not Working NoDents L-Series General 6 10-25-2005 10:04 AM
