Old 10-06-2017, 02:36 PM   #1
JSTDV8
JSTDV8 has a spectacular aura aboutJSTDV8 has a spectacular aura about
2008 VUE 3.5L
2002 VUE 3.0L
Default SL2 lags bad on acceleration
So I just bought this car. It's got 83k on it, no leaks or anything noticeable.
When I first test drove it I didn't notice anything at all.
So, a few things it does that are all related.
1.) When you start it if you put it in gear before it gets to its final idle RMP it will just die.
2.) When you do wait for it to get a good idle first and then put it in gear it drops down pretty significantly and then revs back up
3.) If you feather the throttle to go it goes fine, but if you kind of give it a bit more than normal throttle it lags so bad that it will die if you don't let up on the gas, once you let up it will continue to try and get it's bearings and then after about 1.5 seconds it will slowly go. Or sometimes it just dies.
4.) If it's in park and you recreate the same thing with the throttle it will be at an idle at about 1100 RPMs and then it will drop down to about 600 like its going to die, but it catches itself and then bounces back and forth between 600 and 1500 RPM until it corrects. Again, sometimes it just dies.
5.) And lastly, two out of about 12 times I've been messing with it at an idle it just starts accelerating RPM's, the first time it climbed to about 2500 before I just shut it off, the second time it climbed to about 1600 and just stayed there and I shut it off and restarted and it came right back to normal idle.
No codes are present.
I tried the obvious and changed the plugs and wires.
The plugs looked like it had a fine layer of oil on it, I'm not sure what that indicates.
Also odd is that the manual says that the firing order is 1342, but I see two different firing orders online, the other being 4123. It only starts with 4123, would not start with 1342
I'm thinking TPS, but i thought I'd check here first as you guys have really helped me in the past with a couple other saturn's I've had.
I read a bunch of other threads abut the subject and someone had suggested getting some Techron complete fuel system cleaner. So I got that, but it says to use it on a near empty tank with at least 12 gallons of new fuel. I'm at just under 1/2 tank. I don't know how long the car had been sitting, so I guess it could have old fuel.
Any other ideas? I'm surprised it can miss this bad and not throw a code.
Add to JSTDV8's Reputation
Rate the quality of this post and help JSTDV8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JSTDV8 is offline   Reply With Quote
Old 10-06-2017, 02:52 PM   #2
billr is just really nicebillr is just really nicebillr is just really nicebillr is just really nicebillr is just really nice
Default Re: SL2 lags bad on acceleration
Firing order is not 4-1-2-3 (which is really the same thing as 1-2-3-4). Have you seen pictures of how those cylinders are numbered, and how each plug wire is to be routed and which coil tower they go to? Lots of threads here about that. Get that sorted out, as a first easy step.
Next, take out the plugs for inspection/replacement and take compression readings.
What year is this beast? If it is OBD2, then use live-data to avoid a lot of guessing and parts-changing about the various sensors.
If you can't get live-data to check the ECT sensor, then remove it for inspection/replacement. The OEM sensors always fail sooner-or-later, so going after that "blind" is a pretty safe guess; and they are inexpensive and easy to change.
Add to billr's Reputation
Old 10-06-2017, 03:05 PM   #3
JSTDV8
2008 VUE 3.5L
2002 VUE 3.0L
The car is a 2001 SL2 DOHC
As far as I can tell
then looking at the car from the front
The Cylinders are numbered 1234 from left to right
And then on the two packs below that are side by side
I currently have them 41 23
I tried the 13 42 twice and the car wouldn't start at all.
Old 10-06-2017, 03:15 PM   #4
I currently have them 41 23.
This is correct You posted right before me
edit: pics of plugs? Where on the plug was the oil; above or below the hex?
Old 10-06-2017, 03:33 PM   #5
As mentioned, remove the coolant sensor for examination and replace it if its the original one. Try not meddling with the throttle stop screw unless you're aware of how factory setup works. Meddling without knowing procedures may result in additional problems with incorrect idle and more. The original faulty coolant sensor creates many issues.
Old 10-06-2017, 04:35 PM   #6
JSTDV8
2008 VUE 3.5L
2002 VUE 3.0L
You guys are unfreakingreal.
Popped the Engine coolant temperature sensor out, sure enough, it looked just like the one fdryer posed with the crack
Napa had one in stock for 30 bucks,
put the new one in. It still lags just a bit, but the main issue is gone where it bounces randomly around RPM range and wants to die.
You guys are seriously my heros.
For others having similar issues that may be reading this.
The sensor is located right behind and under the upper coolant line where it connects to the motor.
13MM deepwell socket and a 2" extension.
Pop the 4 prongs off the air box and remove the rubber hose at the back of the air tube so you can flex the air tube out of the way. Or take 1 more step and take the clamp off the other end of the tube and remove it entirely.
Find the sensor (it has two wires coming out of it) Squeeze the little plastic ring around the sensor and gently wiggle it outwards and it pops right off.
13MM deepwell socket, take out the sensor, a little coolant will leak out, but not much. Put the new sensor in, don't overtighten it.
Plug the wire back on paying attention to where the indents on the outside of the sensor are and line those up perpendicular of where the squeeze points are on the wire. plug it in. Replace the Airbox cover and hose and you're all set.
10 minutes tops.
Thanks again guys!!
Old 10-06-2017, 03:10 PM   #7
+1 to what billr said, ECTS is the next thing I would check (unless it is an '02).
Sounds to me more like a fuel and/or sensor issue rather than spark/ignition, but including info below anyway
Spark plug wires at the plugs are 1 2 3 4
They connect to the coil towers 4 1 2 3
1 & 4 should run parallel for most of their length, ditto 2 & 3
This is a SOHC engine, but same principle (attached a color coded one for clarity)
A/C and Acceleration auralsphere S-Series General 5 05-21-2009 08:20 AM
No acceleration Onion S-Series Tech 4 12-07-2008 08:39 PM
acceleration... bskicrash1 S-Series General 11 06-03-2006 09:32 PM
0 - 4,000 vs. 4,000+ RPM Acceleration WopMaster8 S-Series General 2 06-02-2006 08:46 AM
100hp lags saturn4 General Saturn Discussion 19 06-25-2001 11:01 PM
