Old 10-04-2017, 02:27 PM   #1
djjsc
djjsc is a jewel in the roughdjjsc is a jewel in the roughdjjsc is a jewel in the roughdjjsc is a jewel in the rough
1997 SL1
1998 SW2
Default ATF & TCC unlocking
What is the relationship of code P0741 (TCC unlocks) to condition of ATF? Can expired/dirty ATF trigger P0741? Anything else I should consider re: diagnosing a persistent but unpredictable P0741? Sometimes it will go weeks w/o triggering. Thanks.
Add to djjsc's Reputation
Rate the quality of this post and help djjsc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djjsc is offline   Reply With Quote
Old 10-04-2017, 03:09 PM   #2
satlite440
satlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud ofsatlite440 has much to be proud of
2001 SL2
Default Re: ATF & TCC unlocking
po741 is an often misunderstood dtc...the term "stuck off" is not totally correct..it is stuck off due to the ecm or tcm in charge of tcc lock up making a decision that evan at 100% pwm on time it is still seeing the slip rate sail past the specification so it inhibits tcc operation to prevent engagement...as to the cause a weak 3rd or 4th gear or a heavly worn toque converter cluch will set this..to eliminate the 3rd or 4th gears you need to know the gear ratio and be able to not only see live data but the freeze frame records of when the dtc set..
shure you can trust the government,just ask us indians all about it...
heavy line the final protective fire line of the dealership
Add to satlite440's Reputation
Rate the quality of this post and help satlite440 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
satlite440 is offline   Reply With Quote
Old 10-05-2017, 11:27 AM   #3
djjsc
1997 SL1
1998 SW2
Default See live data......... freeze frame records
Can't see that happening; GM stealerships here want minimum $140 just to hook up scanner.
Old 10-05-2017, 11:51 AM   #4
I think you can get OBDII readers in the states for $60~100 US that can read live data and freeze frame. Bluetooth readers and phone/tablet apps are less
Not sure about availability in the Great White North.
Doors unlocking and locking on their own. houstontexanfan S-Series General 9 08-18-2010 10:23 AM
outside lights when unlocking proneto911 S-Series Tech 0 03-14-2010 11:38 PM
Unlocking all doors from outside with key dhbailey Ion General 5 01-29-2008 01:28 PM
Horn chirps when unlocking stuntman Vue Tech 1 04-24-2007 08:12 PM
unlocking door J Lo L-Series General 5 11-05-2005 01:50 PM
