Old 10-03-2017, 10:00 AM   #1
seymourj98
seymourj98 is on a distinguished road
1994 SC2
Default Timing Cover bolts
For the timing cover, I've got 15 bolts - 13 long ones, 1 medium bolt, and 1 short bolt, in addition to the 4 oil pan bolts. I've concluded that the medium bolt probably goes in one of the two middle bolt holes, but I tried every hole on the timing cover and they all seem to be too deep for the short bolt.
1994 Black and Gold Saturn SC2 156k
Add to seymourj98's Reputation
Rate the quality of this post and help seymourj98 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
seymourj98 is offline   Reply With Quote
Old 10-03-2017, 10:35 AM   #2
Default Re: Timing Cover bolts
It's been 8 years or so since I've done this, but IIRC, both bolts should be 30mm long?
The lower center bolt is 8mm head and upper center ( and all outer) bolts are 10mm head (again, IIRC)
Wonder if the cover has been off before, and a bolt fairy took one of the center bolts. http://www.saturnfans.com/forums/sho...d.php?t=142219
Old 10-03-2017, 01:52 PM   #3
seymourj98
1994 SC2
The cover has indeed been off before, but I have 15 bolt holes and 15 bolts for the holes. The previous owner must've lost a bolt and grabbed whatever he had. Thanks for the info, I'll run to the hardware store to pick up a bolt to match the medium length center bolt.
Old 10-04-2017, 03:17 PM   #4
seymourj98
1994 SC2
The M6x1.0 bolt threaded in fine on the bottom of the two center bolt holes, but was like a hotdog down a hallway in the top center holes. None of the bolts that I pulled off of the timing cover would thread in, and there is no visible damage to the threads. Short of buying one of each metric threaded bolt from the hardware store, I'm not sure how I'll find the right size. I wish there was a keychain with studs of every thread size for situations like these.
Old 10-05-2017, 12:52 AM   #5
bachands
bachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to beholdbachands is a splendid one to behold
You mean one of these:
http://www.threadtoolsupply.com/inch...-checker.html#
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bachands is offline   Reply With Quote
Old 10-05-2017, 10:30 AM   #6
seymourj98
1994 SC2
There goes my business plan!
Timing Cover Bolts Aysle S-Series General 4 04-20-2013 05:27 PM
Timing Cover Bolts donmega884 S-Series General 1 03-25-2012 09:04 AM
Plastic valve cover bolts arer bolts are different size than aluminum cover bolts RobertGary1 S-Series Tech 8 08-30-2011 09:52 PM
Different Timing Chain cover bolts? Blammer S-Series Tech 5 11-07-2007 06:22 PM
thread pitch of timing cover bolts geartooth94 Miscellaneous Tech 4 10-20-2004 05:07 PM
