Old 09-30-2017, 09:37 AM   #1
cam
cam is on a distinguished road
cam's Avatar
2007 VUE 2.2L
2007 ION-3 Sedan
Default Horn
I would like to replace my original horn for something louder. Is it an easy task or best left to a pro?
Any recommendations for brand or type of horn which basically will install easily when old one is removed.
Add to cam's Reputation
Rate the quality of this post and help cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cam is offline   Reply With Quote
Old 09-30-2017, 11:05 AM   #2
atikovi
Default Re: Horn
Back in the 70's and 80's I installed one of these http://www.hadleyadvantage.com/produ...y-air-horn-kit into every new car my parents bought. Not gets more peoples attention than leaning on an air horn mounted in a little Dodge 024. Everything fit underhood too.
Add to atikovi's Reputation
Old 09-30-2017, 02:39 PM   #3
Default Re: Horn
You might consider adding another horn with a different pitch. I'm not certain what the pitch of your horn is. On my LS1 it's an "A" (A 440, for the musically inclined). AC Delco used to provide a two lower pitches, "D" & "F", and one higher, "C." The higher pitch will give you more "bang for your buck" because higher pitches cut through other sounds around them more easily. Their products may be easier to install since the wiring connectors are usually included. It should require relatively little effort to adapt them into the system.
You would need to contact someone at AC Delco to help you with the pitch selection you'd prefer. In order to determine which pitch is on your VUE (if you have no musical background) use YouTube and search for a D, F, A, or C pitch and compare it with the sound your horn is making.
288,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 10-09-2017, 09:56 AM   #4
cam
cam's Avatar
2007 VUE 2.2L
2007 ION-3 Sedan
Default Re: Horn
Not sure what pitch it is but all I know is that far too often other drivers are drifting into my lane and I lean on my horn but no one can hear it. I think it's time to get it replaced. Where is the horn located on the VUE?
How to correctly wire 12v 40amp relay for air horn system from 3 wire horn connector? demoncamber S-Series Mods 2 06-20-2013 12:44 PM
horn trouble-no power to horn/not fuse 2xsl2 S-Series Tech 6 03-06-2010 10:32 PM
expiermented to day on 97 sc1 horn replaced with honda horn,whadda ya think! maestro S-Series Tech 1 07-26-2007 11:52 PM
VUE horn location - adding 2nd horn? Robert H. Vue Tech 3 09-11-2006 03:20 PM
Horn Dead, Its Not The Fuse , Cant Find Horn justinkr58 S-Series General 2 07-01-2005 05:39 AM
