Old 09-02-2017, 11:49 PM   #1
lmmoquin
lmmoquin is on a distinguished road
2008 Astra XR
Default A Six Speed?
Hello everyone. I'm wondering at the probability of a new transmission. I know that it would require a LOT of things, but bare with me. My thinking is that, in a perfect world, you might be able to get away with putting the 6T40 transmission from the Chevrolet Sonic into an Astra since both cars use the 1.8l transverse Ecotec engine. The Sonic is a smaller car, so it's transmission should fit? I'd love to hear any thoughts on this.
2008 XR Coupe
Ultra Blue
Bone Stock
Add to lmmoquin's Reputation
Rate the quality of this post and help lmmoquin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lmmoquin is offline   Reply With Quote
Old 09-04-2017, 12:46 AM   #2
nicolas_p
nicolas_p will become famous soon enoughnicolas_p will become famous soon enough
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Default Re: A Six Speed?
I would be very interested to see if this was possible aswell or even the m32 from the 6 speed in the 2.0l in europe
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Add to nicolas_p's Reputation
Old 09-05-2017, 09:17 AM   #3
TDA
TDA is on a distinguished road
2008 Astra XE
I'm no help as far as getting it done... but it makes sense.
Taking an Astra on the highway gets you less MPG than expected. In 5th at ~55 it's cool and will report high 40s MPG. But if you start getting up to 65-75mph, MPGs plumit to the mid to low 30s. Sure sign that another gear is needed for high speed highway driving.
Having the 6-speed would help explain our funky reverse position as well...
Add to TDA's Reputation
Rate the quality of this post and help TDA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TDA is offline   Reply With Quote
Old 09-05-2017, 07:14 PM   #4
AstraFasta
AstraFasta will become famous soon enough
Some European boards discuss the 18xer engine possibility with a 6-speed swap (Astra and Vectra).
One of the issues is the very low power of the engine.
https://www.vectra-c.com/forum/showt...speed-gearbox&
Old 10-29-2017, 04:01 PM   #5
RobD1517
RobD1517 is on a distinguished road
RobD1517's Avatar
2008 Astra XR
The use of 6th gear being only good on the "motorway" translates to me the motorway is higher speed. I don't know about y'all, but I'm at highway speed as much as I am 35-50 mph. 50+ in 6th in my mind would be perfect, just depends on the gearing the 6 speed has.
I've done some research myself into the matter, but I don't think the 6 speed the Vectra uses is available over here is it? I know the bolt pattern on the Cruze and Sonic 1.8's are different from the z18xer, or atleast it appears that way atleast.
'92 SL2 - 108,000 miles (traded)
'96 SL2 - 312,000 miles (blew up)
'98 SL2 - ??????? miles (parts car)
'99 SL2 - 168,000 miles (Sold 11/08)
'08 Astra - 131,000 miles and counting!
Add to RobD1517's Reputation
Rate the quality of this post and help RobD1517 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RobD1517 is offline   Reply With Quote
Old 10-29-2017, 05:27 PM   #6
There may be some issues not mentioned besides physical dimensions for direct bolt on of this six speed auto. Early Saturns used the single PCM to run the EFI system and xmission. Electronic controlled xmissions became the next generation of xmissions. Later models required two separate modules, one for the engine and the other for the xmission, due to more sophistication. Add a third module, the body control module, and Saturns evolved along with other cars in sophistication. The problem of addressing a different xmission from another car may require asking the technical questions of whether or Astra electronics can recognize a foreign xmission and accommodate the extra gears to shift the extra gear two a stock Astra xmission doesn't have.
Will the stock ECM and TCM (transmission control module) need one or both modules (if Astras have two or three modules) updated (if they can) or if they need one or both modules from the other car to make this Astra one off workable. Then the question whether or not the other ECM/TCM will run the Astra engine. Like any complex project, the devil is in the details. To discuss some factors involved in engine/xmission relationships, the engine computer either controls xmission shifts or relegates this control to a separate xmission control module with both ECM and TCM communicating with each other at all times. Engine management deals with all the sensors needed to make an engine run. To make electronically controlled xmissions shift up and down requires more programming to use the same engine sensors like map, throttle position, spark timing, coolant temps, etc. And add xmission sensors to this mix. A lot goes on just running the EFI system. Add xmission programming and things get more complicated and thanks to engineering on many levels, we have 5, 6, 7 and 8 speed xmissions for us shiftless drivers. While a little slow to understand the need for more gears in autos, it didn't occur to me the extra gears allows for quicker off the line acceleration (lower gearing) for things like stoplight racing or more importantly short on- ramps on older roads as well as one or two over drive gears for better fuel mileage at higher speeds while cruising. Separate engine and xmission management systems working together. Xmission shifting looks at engine rpm, load (map sensor) throttle position, coolant temps and spark timing, some factors a xmission control module examines, including the xmission input/output speed sensors to make correct shifts whether stop light racing or granny driving.
If some of this seems a little overwhelming, it isn't when considering what actually goes on with electronics needed to monitor our lead foot while driving in every weather condition our cars, trucks and SUVs are subjected to. And I haven't added abs, tc, and stabilitrak.......
Removing the Speed Limiter: Disconnecting the Input and Output Speed Sensors AlexofNazareth S-Series Mods 35 11-19-2010 06:21 PM
More Six-Speed Automatics Coming as GM Announces Plan to Close 4-Speed Transmission P Charlie General Saturn Discussion 1 05-13-2008 07:49 AM
Any reason to upgrade to the 2.4 w\6 speed over the current 4 speed? Aratech Aura General 5 05-10-2008 03:15 PM
'01 Speed Chip and Speed Boost? (from eBay) Disturbed_One S-Series Mods 46 02-23-2008 12:11 PM
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? 2k3L300HID L-Series General 64 03-10-2005 10:53 PM
