Old 06-07-2017, 03:30 PM   #1
bigjohnmlb
bigjohnmlb is on a distinguished road
Default where the heck is the ambient temp sensor???
any help would be GREATLY appreciated.... thanks guys
Add to bigjohnmlb's Reputation
Rate the quality of this post and help bigjohnmlb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigjohnmlb is offline   Reply With Quote
Old 06-07-2017, 08:12 PM   #2
paperman
paperman is on a distinguished road
2009 Outlook XR
Default Re: where the heck is the ambient temp sensor???
Behind the front grill opening, below the solid bumper cover, drivers side.
Hard to get to without removing the entire front cover.
Add to paperman's Reputation
Rate the quality of this post and help paperman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paperman is offline   Reply With Quote
Old 11-06-2017, 05:21 PM   #3
Doug C
Doug C's Avatar
2008 Outlook XE
Question Re: where the heck is the ambient temp sensor???
Is this the temp sensor that on the DIC tells me intermittently to be aware of icy road conditions at say -4c when the actual outdoor temp is actually say +20c .
While on warranty had Saturn(Canada) supposedly replace the temp sensor. 3rd one still exhibits the intermittent problem.
When it errorneously states lower than +4c no air conditioning till travel enough that the computer sys somehow gets the correct signal thru.
Oh, second time in they replaced a portion(?) of wiring to include the aux button, with a more intuitive (IMHO) button that states "Rear".
Reading the previous post about location of this 'ambient temp. sensor' and not hearing or seeing any evidence of them peeling off the "front cover" to remove temp sensor and still having intermittent incorrect temp readings wonder if SaturnCanada dealership ever did swap out the sensors as indicated on workorder ... too late now.
doug c
Add to Doug C's Reputation
Old 11-06-2017, 07:47 PM   #4
This may help or not - from Saturn Vue files, an image of the ambient temperature sensor hidden behind the front facia (bumper?). Removal of the front bumper is necessary on Vues to have access to removing/replacing it. Looking under the front bumper for a two wire harness leading to the sensor may help before attempting to remove the bumper. Service manuals no longer have photo illustrations, detailed line drawings or black and white photos to show where things are. Drawings are for Vues, not Outlooks. Mine (L300) peeks out behind the lower grille opening and visible.
Old 11-23-2017, 10:28 PM   #5
Behind the front fascia, below the grille/driver side. #2 in the attached image
Excerpt from the TSB to fix the temp display quoted below, full TSB attached (includes how/where to relocate the temp sensor).
Originally Posted by TECHNICAL Bulletin No.: 08-01-39-008A
Date: March 30, 2009
Subject:
Ambient Air Temperature Sensor Display In Instrument Panel Cluster (IPC) Inaccurate Or Reads Too High (Reposition Ambient Air Temperature Sensor and Reprogram HVAC Control Module)
Models:
2007-2008 GMC Acadia
2007-2008 Saturn OUTLOOK
Supercede:
This bulletin is being revised to update the parts information. Please discard Corporate Bulletin Number 08-01-39-008 (Section 08 - Body and Accessories).
Condition:
Some customers may comment that the ambient temperature display is inaccurate or reads too high.
Correction:
Technicians are to relocate the ambient air temperature sensor to a new location and reprogram the Heating Ventilation And Air Conditioning (HVAC) Control Module.
Old 02-02-2018, 05:39 PM   #6
Doug C
Doug C's Avatar
2008 Outlook XE
Wow.
Thanks for compiling and sharing all that info !
Will make copies in case myself or possible new owner of unit wants to attempt
All the front end assemblies, removal for one small part LOL
Theeen acquire some software file update from somewhere LOL.
doug c
02 saturn l300 ambient temp sensor mrhappypantz L-Series Tech 13 07-31-2016 09:07 PM
CEL P0073 Ambient Air Temp Sensor amciver15 Astra Tech 5 04-06-2015 04:53 PM
Part No for Ambient outside air temp sensor EHuntress S-Series Tech 2 05-30-2013 04:04 PM
ambient temp sensor inaccurate greenman Aura General 0 12-03-2010 03:01 PM
LW200 Ambient Temp Sensor Urbanrover L-Series Tech 0 11-04-2007 11:25 AM
