Old 11-18-2016, 06:53 AM   #1
trailer0187
trailer0187 is on a distinguished road
Default 1998 saturn misfiring
1998 saturn(salvaged) sc1 1.9L SOHC automatic
transmisson power steering and AC. With 210,000 miles on it. I have owned it for 7 years. Three years ago the ECM had to be replaced.
Last week it began to misfire, bog down with no power. It runs great cold once it hits operation temp it misfires , floods the engine and stalls with no get up and go.
I had drained the tank, checked the fuel rail for fuel,checked the injectors and moved them around to change it up, cleaned all grounds and inpected most connecting points.
replaced the ECM, coolant sensor, TPS ,MAP SENSOR, CRANK POSITION SENSOR,FUEL FILTER, PLUGS, PLUG WIRES, both pulleys on front of motor,ck voltage while running bad and good.
service light comes on and the ck eng light comes on with multiple codes P0120,P0125,P0711,P0340. But each code has a identical code with Pd at the end. meaning fixed.
It has a cold air intake on it. When it runs cold it runs great once it warms up it barely will stay runnig or move.
thank you trailer0187
Add to trailer0187's Reputation
Rate the quality of this post and help trailer0187 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trailer0187 is offline   Reply With Quote
Old 11-18-2016, 07:14 PM   #2
Default Re: 1998 saturn misfiring
The things not mentioned; fuel pump pressure before and after engine power is lost, catalytic converter and egr valve.
2002 Saturn SC2 misfiring StitzieJ S-Series Tech 1 11-11-2015 03:18 PM
Saturn sw2 misfiring and hesataiting Darkone S-Series Tech 2 06-03-2014 07:44 PM
06 Saturn Vue v6 stalling and misfiring sixtyonenorth Vue General 13 07-09-2013 08:58 AM
2002 saturn sl1 misfiring BlindedLegacy S-Series Tech 3 04-14-2011 11:10 AM
FS: Ultra rare Saturn SL2 (1998) Mint in Saturn box CFVWTUNER Classifieds 5 11-22-2005 06:54 PM
