Old 08-10-2015, 09:00 PM   #1
hawksking
hawksking is on a distinguished road
Default Stereo not working
I made another post about how my car got flooded and was having problems. Everything is fixed but now the stereo stopped working. It was working fine for the last few days after the flood but this morning I noticed it didnt work at all. I press the buttons nothing happens. I plugged in my iPod I used in that car everyday using AUX cable and still nothing. I think i can see faint orange pixelated lines on the left and right side of the screen but I see those even when the car is off, so not sure what is going on.
I've thought of just replacing the whole thing but I think the problem might lie on the other side of the connector which connects to the car since water only got to the floor and not anywhere near the stereo at the top.
Car is a 2007 Saturn Ion Quad Coupe
Googled a picture, stereo looks like this.
ecarshawaii.com/images/hosted/2007-saturn-ion-level2/2007-saturn-ion-level-2-sedan-11.jpg
Add to hawksking's Reputation
Rate the quality of this post and help hawksking reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hawksking is offline   Reply With Quote
Old 08-10-2015, 09:18 PM   #2
ruley73
ruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to all
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Stereo not working
It sounds to me like the radio either isn't getting any power or might need to be replaced. Check all relevant fuses and if they are fine just keep them removed for a few minutes to try to reset the radio. Here's a link to a super cheap replacement that has the 6CD changer. I'd normally recommend the single disc radio, but for $25 that 6CD radio is a steal. It would be a direct plug & play swap too because Ion radios don't need to be programmed.
2007 Ion 2 Quad Coupe 5-speed manual 177K miles
2007 Chevy Equinox LT 177K miles
Add to ruley73's Reputation
Old 08-10-2015, 09:29 PM   #3
hawksking
Originally Posted by ruley73 View Post
It sounds to me like the radio either isn't getting any power or might need to be replaced. Check all relevant fuses and if they are fine just keep them removed for a few minutes to try to reset the radio. ebay.com/itm/06-07-Saturn-Ion-Vue-Radio-CD-Player-Aux-Port-TESTED-9455-/400940782144?hash=item5d59eed240&vxp=mtr"]Here's a link to a super cheap replacement that has the 6CD changer. I'd normally recommend the single disc radio, but for $25 that 6CD radio is a steal. It would be a direct plug & play swap too because Ion radios don't need to be programmed.
I have no clue on how to check the fuses, sorry I am a complete amateur. I would buy another unit but I'm afraid it might be a problem with the wiring connecting to the car somewhere and not the stereo itself and I would end up spending money on something that I didn't need.
Old 08-10-2015, 10:04 PM   #4
ruley73
ruley73's Avatar
I wouldn't replace the radio until I knew it was bad either. You should learn how to check fuses. It's not hard at all. Google and YouTube are your friend. The Ion has two fuse panels, one under the hood and another on the left side of the console near the driver's footwell. The latter is the one that contains the radio fuses. Pull out the two radio-related fuses and look at the metal part in the plastic housing. If there is a break in it the fuse is bad.
Old 08-10-2015, 10:46 PM   #5
hawksking
Looked at some videos and I think I know what to look for now and how to check it.
Is it Fuse #21 for the stereo in that picture?
Old 08-11-2015, 12:31 PM   #6
ruley73
ruley73's Avatar
That fuse is only used for the factory amplifier if your car is equipped with it. The two fuses for the radio are in the I/P fuse block which is on the left side of the console near the driver's footwell (see pictures attached below).
factory stereo not working after I reinstalled it. ddemier7 Ion General 3 11-30-2014 04:20 AM
I need stereo wire diagram for 04 Ion level 1 need advice on aftermarket stereo ddemier7 Ion General 3 10-19-2014 11:25 PM
Found out why car stereo wasn't working.... MR2 S-Series General 0 12-28-2009 08:33 PM
Help with aftermarket stereo not working sparkynsmoke S-Series Tech 3 03-19-2007 07:42 PM
HELP, stereo wiring not working jumpn Vue General 4 11-12-2004 12:42 AM
