Old 02-09-2014, 01:12 PM   #1
haloelite482
haloelite482 is on a distinguished road
Default 2004 vue ignition switch issue
So I started having the car wont start in really cold weather and discovered it was the ignition switch, so I switched my old one for a new one and when I went to do the relearn passlock procedure, my car just started up normally. Does this mean it wasn't the ignition switch, because I had the security light blinking when my car wouldn't start which is what happens when the issue is the ignition switch. Anyone else had this happen to them? Should I be worried?
Add to haloelite482's Reputation
Rate the quality of this post and help haloelite482 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
haloelite482 is offline   Reply With Quote
Old 02-09-2014, 01:34 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2004 vue ignition switch issue
Does sound weird - how much of ignition switch assembly did you change?
Passlock sensor is part of the outer lock cylinder housing. There's a small connector (3 wires) that plugs into Passlock sensor near where key is inserted.
Changing only inner key cylinder wouldn't affect Passlock. Perhaps the new key cylinder rotates smoothly from OFF to START and the original was "grabbing" as it turned.
Old 02-09-2014, 03:57 PM   #3
haloelite482
I only changed the ignition switch did not replace the key cylinder. I will test when the temperature gets really cold.
Old 02-14-2014, 03:33 PM   #4
haloelite482
UPDATE: The car has started normally several times in temperatures from 0-10F so I think im good.
2004 Vue Door Switch / Lock Issue Ravenmike Vue Tech 13 02-15-2015 02:21 PM
2004 ion security light (+ignition switch) carl bruce Ion Tech 4 01-09-2014 12:42 AM
Ignition Switch Issue.... AJEsquire Vue Red Line 14 04-23-2013 09:43 PM
2007 Ion startig issue (not ignition switch!) James614 Ion Tech 9 04-03-2013 09:21 AM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
