Old 03-27-2013, 05:58 AM   #1
James614
James614 is a jewel in the roughJames614 is a jewel in the roughJames614 is a jewel in the rough
Default 2007 Ion startig issue (not ignition switch!)
Okay, so have a weird issue. The car was running fine until after sitting for 2 weeks where the battery died. I guess the passlock relearn had to be done afterwards, but in the process of troubleshooting the starter was replaced with a reman. Now, the car tries to start normally, but the starter spins without turning the engine. I had the starter tested and it spins rapidly and extends as it should. The teeth on the flywheel and starter are intact. Is there an electrical issue that could cause this?
Add to James614's Reputation
Rate the quality of this post and help James614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
James614 is offline   Reply With Quote
Old 03-27-2013, 07:09 AM   #2
Default Re: 2007 Ion startig issue (not ignition switch!)
Replace the starter. From descriptions, this seems to be a faulty starter gear - the one-way bearing failed. You can test this yourself; with the starter off the engine, use a strong thumb to rotate the starter gear - one-way bearings will allow turning starter gear in one direction only and not in the other direction. Failed ones will allow the gear to turn in both directions. Its rare for it to fail but they do. The starter gear is recessed in its housing and can be pried out against its return spring without harm or by applying 12v to the solenoid (only) to pop the starter gear out too while manually turning the gear. 12v applied to the small terminal on the starter solenoid, ground on the starter frame.
Old 03-27-2013, 08:36 AM   #3
James614
The starter gear doesn't turn with no voltage applied to it, in either direction from what I could tell. Should it only turn with 12v applied to the small terminal? I extends and retracts fine when you put 12v to it.
Old 03-27-2013, 09:47 AM   #4
Leave 12v on to power the solenoid; this extends the starter gear/one-way bearing to the engaged position as it would be in the engine to turn the engine flywheel. On good starters you should be able to manually turn the starter gear in one direction only - this is the released direction when the starter is left ON and the engine is running to prevent damaging the starter motor. The one-way bearing is a clutch to grab in one direction, the direction the starter motor is turning with the clutch engaged so the gear can turn the flywheel. As soon as the engine runs the flywheel will turn faster than the starter gear - the clutch disengages/releases and allows the gear to over run without turning the starter motor. The gear should be free to turn in one direction only. The other direction is against the motor and will turn the motor with difficulty.
If the gear is jammed in its one-way bearing then you found it this way and may be able to free it with force against the gear teeth. At this point the gear is already damaged. If you have a warranty, replace it otherwise another starter is needed. Replacing the one-way bearing/starter gear is possible but requires good skills to disassemble the starter, find the replacement, and reassemble everything back for final testing on the engine. This isn't for the average DIYer.
Old 03-27-2013, 11:36 AM   #5
James614
Thanks for the detailed and fast responses. I will test it out again when I get home. At this point I'm really kicking myself for sending off the old starter for the core when it wasn't the cause of the original issue, and this reman'd POS is definitely of much worse quality than I would have anticipated.
Old 03-27-2013, 02:52 PM   #6
Its unfortunate to buy a faulty reman'd starter when you're expecting good value but this does occur from time to time.
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
Ignition Switch Issue.... AJEsquire Vue Red Line 14 04-23-2013 09:43 PM
03 Vue anti theft issue and ignition issue jamil0810 Vue General 4 07-17-2012 01:43 PM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 04:47 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
