Old 02-28-2012, 02:12 PM   #1
Agent Runkle
Agent Runkle will become famous soon enoughAgent Runkle will become famous soon enough
2002 SL
Default I Just Remebered I Haven't Change My oil since 2007!
Sometimes you just get busy and things slip your mind...
I have a 2002 SL with 160,000 miles and have owned it since new. Runs great and just recently had to fix a few minor things due to the year and millage, nothing major.
For a few months now I been thinking about my oil situation and wondering what I should do about it. I do add a qt about every 1,000 miles and that's about all I been doing since the summer of 2007 (sadly, I'm serious). My thought is that I should order about 12 filters and a ton of oil and change my filter and oil about every 500 miles until I feet better about it but I been reading options like adding diesel or kerosene (just a little) to the oil and running it then draining it. My fear is knocking some chunk of something loose and blowing up the motor.
Thinking my best bet is the frequent oil changes and don't add anything to the engine.
Any ideas? or just keep going another 70,000 and see what happens?
Thanks,
Mr. Lazy
Add to Agent Runkle's Reputation
Rate the quality of this post and help Agent Runkle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Agent Runkle is offline   Reply With Quote
Old 02-28-2012, 02:14 PM   #2
ShawnV
ShawnV has a spectacular aura aboutShawnV has a spectacular aura about
ShawnV's Avatar
1996 SW2
2000 SW2
Default Re: I Just Remebered I Haven't Change My oil since 2007!
I would do the shorter interval oil changes and not add anything to the oil.
Let's see what others have to say though.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 02-28-2012, 02:19 PM   #3
Cheyne
Cheyne will become famous soon enough
1999 SC2
I thought this was a joke at first. Don't add any additives to the crankcase. Change the oil and use a good quality oil filter like the Pure One PL20195. I would do a couple of quick OCI's. You will probably fill up the filter pretty quickly. Current one is likely in bypass.
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
Old 02-28-2012, 02:26 PM   #4
Agent Runkle
2002 SL
Nope, not a joke and I know better but after a while I was amazed it was still driving good and still great on gas around 32mpg city and 38-40 on the highway.
When I was looking under there a few weeks ago I did notice a mess of thick oil cruded up all over my pan (towards the pulley) . I ordered a Floor jack and jack stands from Harbor Freight and the stands made it and now I'm waiting for the floor jack to show up today. Then I'm in business for safely getting under there to do some scraping and cleaning. I think from my first look I'm building up some oil around the outside of the filter.
I'll take pictures of this mess, I'll 75% ashamed and 25% amazed!
I'm getting online to find those filters now.
Old 02-28-2012, 03:00 PM   #5
bountyhunter
bountyhunter will become famous soon enoughbountyhunter will become famous soon enough
1992 SL2
+1 Buy gallon jugs of decent oil at Walmart (like Castrol, Valvoline etc) and change your oil everytime it gets dark. I'd wager you have some gunk in there to get out.
You can also do the five minute flush thing at the oil change. I used to do that, but now I just change the oil more often and it never gets dirty.
Add to bountyhunter's Reputation
Rate the quality of this post and help bountyhunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bountyhunter is offline   Reply With Quote
Old 02-28-2012, 03:38 PM   #6
Puck head
Puck head is on a distinguished road
1997 SC2
Wow! It's a miracle your engine is still running. Probably means it was a good engine. Might still be but only time will tell. I'd definitely drain oil immediately and take off valve cover and inspect and get any big clunks if any out. And take off oil guides on the valve cover and clean all sludge. I did this to my car at around 210,000 miles and I change my oil on time every time since I got the car with 121 k. There was quite a bit of sludge in the oil guides. And then take off oil pan and inspect for oil sludge build up. Then use mObil 1 and their filters from now on. Especially if your the neglectful type. I strongly recommend u do this. I guarantee your motor will love these things done to it. Fuel filter? Air filter? Tranny filter? All these are cheap and easy to replace. That's why I love my Saturn so much it's affordability and it's easy to work on.
Add to Puck head's Reputation
Rate the quality of this post and help Puck head reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Puck head is offline   Reply With Quote
Old 02-28-2012, 04:07 PM   #7
ShawnV
ShawnV's Avatar
1996 SW2
2000 SW2
I wouldn't do this at all. It could easily loosen things up and kill the engine quickly. I did the Gumout motor flush and killed an engine a few years ago.
shawn
Old 02-28-2012, 04:08 PM   #8
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Someone just did the MMO flush and killed an engine.
The proper procedure is to change the oil and filter, drive for a couple of hours at full operating temperature and change the oil and filter again. Use a Mobil-1 209 or Pure One PL20195 filter and top quality oil. Change again at 1000 miles.
Old 02-28-2012, 04:49 PM   #9
Agent Runkle
2002 SL
Thanks for the tips. Aside from this little mishap I always kept everything else maintained. Its been driving easy since day 1 and so far I'd say I got my $9,999 out of my Spring Special.
With all the positive talk and memories of my little car I'm starting to feel bad for the little guy knowing I'm going to end up giving it to my teenage daughter..poor car.
BTW on a side note I just got my Jack from FedEx and already used it!
The 3ton Rapid Pump from Harbor Freight for $65 and 3 Ton Jack Stands for $15 is a awesome deal!
2007 Vue 4cyl coolant change maddog505 Vue General 3 10-02-2011 09:23 PM
2007 Vue Oil Change Towjumper Vue Tech 3 01-02-2008 09:06 PM
2007 Vue brake fluid change greensaturn Vue General 16 12-31-2007 11:08 PM
2007 Ion oil change....help Frez Ion Tech 40 09-09-2007 08:37 PM
2007 Vue first oil change greensaturn Vue Tech 5 12-03-2006 01:44 PM
