Old 02-06-2012, 03:17 PM   #1
SlowRide
SlowRide is on a distinguished road
SlowRide's Avatar
1998 SW2
Default How Urgent is TPS replacement?
I've had my '98 SW2 for about 2 months and it seems that the TPS is failing, from what I've read here in the forums. A couple times the idle stayed high, ~1500 rpm, after driving ~45 minutes. The first time I tapped the accelerator and it went back to normal which was ~850rpm. I cleaned the TB (in place) and after that it has been idling at 800. about 6 weeks later, I had another episode of high idle, which did not go away with tapping the accelerator, but went away after turning the car off and restarting. Does this sound like a failing TPS? Can the TPS failure cause the car to be undrivable?
1998 SW2 5spd 66k mi
1999 C5 hardtop
2007 Magnum SRT8
Add to SlowRide's Reputation
Rate the quality of this post and help SlowRide reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlowRide is offline   Reply With Quote
Old 02-06-2012, 03:33 PM   #2
TXSaturn02
TXSaturn02 has a spectacular aura aboutTXSaturn02 has a spectacular aura aboutTXSaturn02 has a spectacular aura about
TXSaturn02's Avatar
Default Re: How Urgent is TPS replacement?
I drove around with my TPS randomly giving me issues for a couple of years. I don't think it really will cause much damage - it will just cause you to burn more oil and gas than it would if it idled normally. Since I didn't spend much time at traffic lights, I let it go for a while. Finally decided to spend the $50 and get it fixed since it is such an easy job. You should get OEM for this part.
2002 SL2 Manual - new in November, 2001
As of 09/30/17: 223,751 Miles - SOLD
New owner As of 01/01/18: 225,000 Miles
2013 Mazda 3 HB - new in October 2012
As of 06/15/18: 49,365 Miles
Add to TXSaturn02's Reputation
Rate the quality of this post and help TXSaturn02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TXSaturn02 is offline   Reply With Quote
Old 02-06-2012, 03:45 PM   #3
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
^+1 - Drove mine that way for a couple years also. With a manual trans, it is less of an issue since either the clutch is pressed or the car is in neutral when coming to a stop. On an autotragic, you might find yourself fighting to stop the car. It is an easy job with the right tools (torx bits and a 1/4 drive ratchet) and small hands. Got my replacement at Autozone and it has worked fine for a couple years now, but OEM is likely best.
BV22
2002 SC1 5M
313k 07/18
Add to BV22's Reputation
Old 02-06-2012, 03:47 PM   #4
SlowRide
SlowRide's Avatar
1998 SW2
how about the AC/delc0 part?
1999 C5 hardtop
2007 Magnum SRT8
Old 02-06-2012, 03:56 PM   #5
TXSaturn02
TXSaturn02's Avatar
I believe most people think AC/Delco is OEM most of the time. You might want to do a search. Sometimes if you ask the guy behind the counter, they'll know if it is OEM or not.
Be careful when removing the screws - if you drop it, you might have a tough time finding it. Unscrew by hand once it gets loose.
Old 02-06-2012, 03:59 PM   #6
SlowRide
SlowRide's Avatar
1998 SW2
rock auto lists the Delphi as OE and it's like $55, the AC part is only $30
1999 C5 hardtop
2007 Magnum SRT8
Old 02-06-2012, 04:04 PM   #7
TXSaturn02
TXSaturn02's Avatar
List the part number and maybe someone else will let you know. For something like that I just go to the Chevy dealership (I paid about $55 for mine). I know some of you live in the sticks and ordering on-line is an easier option.
URGENT: Old Nuc I need help! Joe S S-Series Tech 17 04-21-2011 08:56 PM
Urgent question 01SL1SATURN S-Series General 10 11-02-2008 10:57 AM
URGENT: Key stuck paulygon S-Series General 16 01-17-2006 11:30 AM
Urgent Girafro S-Series Tech 8 12-06-2004 12:43 PM
URGENT: Help Needed! thewretched Miscellaneous Tech 4 08-02-2004 04:21 PM
