#1 | ||||
![]() Join Date: Jan 2012
So my Ion has had some starting issues of late. I replaced the battery based on the results of my load test. Didn't fix it.
I got an ignition switch and spent the half hour resetting the Passlock. The lock symbol is gone, but no cigar. Nothing happens, I don't even hear the fuel pump. ![]() The LCD says "Power Str" and "Coolant". I scanned it with my OBD II and it found no faults. I don't see any plugs I might have bumped during the replacement of my switch. Any ideas? I need to get to work tomorrow... Thanks in advance.
#2 | ||||
![]() Join Date: Apr 2009
2004 ION-2 Sedan
Check BCM for both current and history codes. you may have to use a tech-2 scan tool.
#3 | ||||
I figured it out. The BWD Ignition Switch didn't work. I bought an ACDelco and opened the box and the switch was in pieces, cheap
For some reason the BWD will confuse the BCM and throw out errors.
#4 | ||||
^ ^ That's simply incredible!? ^ ^
... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#5 | ||||
![]() Join Date: Jul 2011
simply
| Thread Tools | |
| Display Modes | |
| 02 LW300 P0343, no start/hard start, noise. | JC316 | L-Series Tech | 2 | 11-29-2011 06:09 PM |
| Quick start cold/ slow start warm 1st try, 2nd try quick start | SWDude | S-Series Tech | 3 | 12-05-2009 09:27 PM |
| Cold start fine, warm start takes a couple of tries | FredM | S-Series Tech | 5 | 09-05-2008 04:03 PM |
| 1999 SL2 Wont Start/Hard to Start in Hot Weather | BlueOgre | S-Series Tech | 9 | 06-28-2007 05:36 AM |
| 2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) | mymimi75 | L-Series Tech | 1 | 08-18-2006 10:50 AM |
