Go Back   SaturnFans.com Forums > Site Information > Support Forum for Canadian Saturn Owners
Old 11-01-2011, 10:05 PM   #1
slaughlin
slaughlin is on a distinguished road
Default 96 Saturn high idle in neutral
I have a 96 manual Saturn SL and recently when I put it in neutral the rpm's go up to 2000-2100, when the vehicle comes to a halt the rpm's drop down to 900ish. When I start the car the rpm's go up to 2000 also. I've cleaned out the throttle body but no change. Any suggestions? Vacuum leak? VSS? Thanks.
Add to slaughlin's Reputation
Rate the quality of this post and help slaughlin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slaughlin is offline   Reply With Quote
Old 11-03-2011, 09:05 AM   #2
Tubagod767
Tubagod767 is on a distinguished road
2004 ION-2 Sedan
Default Re: 96 Saturn high idle in neutral
You might get a better response if you post in the proper forum for your model. But, I had a similar problem with my '04 ion. It turned out to be a faulty TPS and didn't throwing a MIL code. I suggest checking the continuity of your TPS.
Add to Tubagod767's Reputation
Rate the quality of this post and help Tubagod767 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tubagod767 is offline   Reply With Quote
Old 11-04-2011, 10:53 AM   #3
keelerpd
keelerpd is on a distinguished road
I had a similar problem in my 99 Saturn DOHC and I first changed out the TPS with no difference. I cleaned the throttle body and this actually made the problem worse. I would suggest you chance the Idle Air Control valve. It easily gets all gunked up (very technical term) especially when you clean the throttle body as all the crap out of the TB gets into it. It made a night and day difference on my car. Before I was unable to keep the thing running and it would "idle" at about 2500 rpm. Now it is at 850-900 all day long.
2004 ION 3 - LE - 114K miles
1999 SL2 - Owned since new, 272K miles (ALAS Sold)
1964 Chevelle - restoring
1965 Chevelle 2 dr post - driver
Add to keelerpd's Reputation
Rate the quality of this post and help keelerpd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keelerpd is offline   Reply With Quote
Old 11-04-2011, 12:28 PM   #4
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
1-If you haven't done so, replace the faulty round nosed plastic coolant sensor with a flat nosed brass one. The faulty one causes rich running conditions.
2-Replace the old thermostat too if the temperature gauge hovers over the 1/4 mark. You'll have better heat too this winter. This in conjunction with the faulty coolant sensor causes higher idling.
3-Once the above are taken care of, a worn tps is easily tested. The next time the idle remains high, park and shut off the engine for a restart; without touching the gas pedal, if the idle returns to normal then its a worn out tps. Replace it.
Perform step 1 and 2 before step 3.
Old 11-06-2011, 12:09 PM   #5
slaughlin
Changed out the ECS and the rpm's are back to a more respectable level. Interesting enough after the first test run I recieved a P0500 code (VSS). Erased the code and it never came back.
Thanks for your help.
Old 11-13-2011, 07:50 PM   #6
saturn/chev
saturn/chev is on a distinguished road
I had the same prob but now my engine check stays on and my coolant level
came on.
Add to saturn/chev's Reputation
Rate the quality of this post and help saturn/chev reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn/chev is offline   Reply With Quote
Old 11-15-2011, 11:06 AM   #7
fm2200
fm2200 is on a distinguished road
2001 SL
Happy Re: 96 Saturn high idle in neutral
What is the ECS??
Add to fm2200's Reputation
Rate the quality of this post and help fm2200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fm2200 is offline   Reply With Quote
Old 11-15-2011, 11:56 AM   #8
ECS or more commonly known as ects - engine coolant sensor, engine coolant temperature sensor.
high idle in neutral bryanb S-Series Tech 31 01-03-2012 09:39 PM
High idle in park and neutral blakerybob03 S-Series Tech 4 03-03-2011 07:50 PM
high idle during neutral hazelblue S-Series Tech 7 10-08-2010 09:07 AM
idle in neutral at high speed joem8357 S-Series Tech 4 09-01-2008 10:28 AM
Please Help - High Idle in Neutral mrt1100 S-Series Tech 12 10-30-2007 07:58 PM
