Old 11-17-2010, 10:13 PM   #1
LowMileSC1
LowMileSC1 is on a distinguished road
Default 2002 SL2 random no start, urgent.
So My 2002 saturn sl2 has had a random no start problem for a few months now.
Iv already replaced the coolant temp sensor, crank position sensor and the fuel filter. And it happens yet again!!!
Any ideas or other common areas to check?
When it starts it runs great...and if you wait 15-20 minutes it starts.
Im lost. Maybe the oil level sensing system?
1996 SC1: Grandma Gold, 5speed 57,000miles
Add to LowMileSC1's Reputation
Rate the quality of this post and help LowMileSC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LowMileSC1 is offline   Reply With Quote
Old 11-17-2010, 11:33 PM   #2
Default Re: 2002 SL2 random no start, urgent.
As long as the security indicator isn't on during starting there are three major items to consider; battery, battery cables, and starter. If the security light is on or flashing during starting then its a factory security system issue.
If the battery is over 5yrs old have it tested to be sure its not beginning to show signs of failing. Winter is the worst time to discover a worn out battery when you can find out now by a simple auto store battery test.
The battery cables carry welding current needed for the starter to run so any signs of corrosion, visible or hidden, must be carefully examined and either cleaned or replaced.
The last to check and the hardest is the starter so if the battery, cables, and connections are checked correctly then the starter may be worn out. Even with little mileage, if this car is used for many short trip drives around town, the starter is used more than twice for the average daily driver going to work and returning home.
Old 11-17-2010, 11:38 PM   #3
madpogue
1996 SW2
"Elephant in the room" question - when it fails to start, does it crank?
There is no oil level sensing system. Other than the dipstick and an owner who knows how to use it.
Add to madpogue's Reputation
Old 11-17-2010, 11:56 PM   #4
LowMileSC1
Yes it does crank.
funny part, this one is my girlfriends car. a few times she has ran it out of oil. and it would not start. put oil in and it was fine!
this time it deffinately has oil!
Old 11-18-2010, 11:20 PM   #5
LowMileSC1
really need some help on this one...
Old 11-18-2010, 11:46 PM   #6
madpogue
1996 SW2
Test for spark during the time when it won't start. It's possible the new CPS is failing just as the old one did.
2006 Ion random no start bad280z Ion Tech 1 10-17-2010 12:29 AM
Random No-Start bigalpha S-Series Tech 4 09-01-2010 11:23 PM
Random no start fixed! Darren1970 L-Series Tech 3 08-25-2009 08:45 AM
Random so start! Darren1970 L-Series Tech 3 08-19-2009 10:46 AM
Random no start issue ob1 S-Series General 19 02-12-2009 11:03 AM
