Old 02-03-2010, 05:06 PM   #1
houstontexanfan
houstontexanfan is on a distinguished road
1997 SC2
Default Doors unlocking and locking on their own.
Today while sitting at a light my car doors started to unlock and lock by themselves and when I got home I couldn't get it to unlock by pushing the unlock button on the door,or doing it manually the lock button wouldn't move. After about five minutes sitting in my car the doors finally unlock again on its on, so what could be the issue.
Add to houstontexanfan's Reputation
Rate the quality of this post and help houstontexanfan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
houstontexanfan is offline   Reply With Quote
Old 02-03-2010, 07:22 PM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
1996 SW2
2003 VUE 2.2L
Default Re: Doors unlocking and locking on their own.
The door lock actuator/switch could be it. This happened to the PO of my 1997 SW2. His mechanic took the switch out because the locks were locking themselves and ultimately killing his battery.
When I got the car I just went to the junkyard and got a new switch for like $2. If fixed the problem.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-04-2010, 12:01 AM   #3
madpogue
1996 SW2
It's more likely the switch than the activator. Behind the bezel, the LOCK and UNLOCK buttons are all one piece, kind of a "rocker" that is held in the "neutral" position by a spring. When that spring fails, stuff like this happens. Could be either switch, but the driver's side gets more use so is the prime suspect.
Add to madpogue's Reputation
Old 02-04-2010, 12:25 AM   #4
ShawnV
ShawnV's Avatar
1996 SW2
2003 VUE 2.2L
+1 driver's side. That was the dud on mine.
Old 02-04-2010, 10:15 PM   #5
thisgirlkrystin
thisgirlkrystin is on a distinguished road
I had this happen last year, the lock sounded like a automatic gun between lock and unlock. I took off the switch because I swear the battery would go dead the way it was going. I noticed that the little pin behind the switch was snapped. I was taking my car to get the oil changed the following day so I just took all the parts in with me and asked them what it would cost to replace it. If it was too much I had some glue and I was going to try putting it back myself. A whole new switch cost $11.95 and the installed it with no labor because I did all the work, they just had to plug it in and pop it in, nothing special about it.
Add to thisgirlkrystin's Reputation
Rate the quality of this post and help thisgirlkrystin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thisgirlkrystin is offline   Reply With Quote
Old 08-11-2010, 09:04 AM   #6
RobsSL2
RobsSL2 is on a distinguished road
RobsSL2's Avatar
I found this is what happened to mine. Where do I buy Saturn parts now that there are no dealers? lol
Rob
1998 SL2 daily driver : 127,000 miles and rising
Add to RobsSL2's Reputation
Rate the quality of this post and help RobsSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RobsSL2 is offline   Reply With Quote
Old 02-05-2010, 08:42 PM   #7
houstontexanfan
1997 SC2
Thanks all for the input going to see about getting the parts to fix the locks.
Old 08-10-2010, 09:25 AM   #8
RobsSL2
RobsSL2's Avatar
Mine started doing this early this morning. I thought maybe some wires were touching but I will have to look into the switch. I pulled the fuse for now so it stopped going crazy.
Rob
Unlocking all doors from outside with key dhbailey Ion General 5 01-29-2008 01:28 PM
auto locking doors carl Ion General 2 11-25-2007 03:37 PM
Horn stopped beeping when locking doors GlennCoco S-Series General 6 11-15-2007 08:41 PM
Doors locking when put into gear mpaetsch Vue Tech 1 06-23-2005 09:57 PM
How do I disable auto-locking doors? My daughter was stuck for 30 minutes!!! chiefscott1701 Vue General 50 02-25-2005 03:18 PM
