#1 | ||||
![]() Join Date: Apr 2008
I have spent hours trying to find the answer to this question myself but hope one of the Pro's will be willing to partake with some knowledge...
#2 | ||||
![]() Join Date: Mar 2008
2001 SC1
Me personally, I just bored out the intake side of my TB and port matched to my manifold, then polished. You'll see gains in throttle response and very little increase in mid-high rpm range because of the steady and faster air-flow. Gains can be more depending on what else you may have done to your engine. Remember, your engine will only take in as much air as it needs unless its forced.
#3 | ||||
Throttle body / transaxle?
#4 | ||||
![]() Join Date: Oct 2007
2000 SL2
I'm definitely not one of those 'pros,' but i'll give it a shot..
"Best"...? for performance? Or just a quality replacement? For performance, you can get a throttle body from a Geo Storm, BUT since your car is 3rd gen, you'll have to swap out the intake manifold from a 99. http://www.sixthsphere.com/phpBB3/vi...p?f=57&t=16518 http://www.sixthsphere.com/phpBB3/vi...ilit=geo+storm hope it helps ... Dan
#5 | ||||
For when the throttle body is so large, and the return spring so heavy, that you need gear reduction between the gas pedal and the TB. Unless you have wimpy legs, go with the wider gear ratios. Gets the TB open faster.
#6 | ||||
Transaxle valve body??
| Thread Tools | |
| Display Modes | |
| 2001 SC2 Transaxle replaced | johnnymozetti78 | S-Series Tech | 1 | 04-13-2009 07:07 PM |
| Problem with 2001 sl2 transaxle | Dolfanjhn | L-Series Tech | 1 | 03-12-2008 01:40 PM |
| Transaxle Leak - 1996 SC1 | rgdingman | S-Series Tech | 12 | 02-28-2008 04:41 AM |
| 2001 sc1 sunroof motor replacement | MacExperts | S-Series General | 2 | 09-14-2007 07:26 PM |
| use 95 solenoid in 2001 transaxle? | mehalski | S-Series Tech | 1 | 08-09-2007 09:06 AM |
