Old 05-26-2007, 01:47 PM   #1
BarnOwl
BarnOwl's Avatar
2000 SW2
Default What and How to Save off of A/C
If you saw my previous thread, you know I'm swapping engines this weekend. The donor car was in a front end collision that took out the radiator. I assumed it took out the condenser too. Well after much destructive work with a 3" high speed cutting wheel, a sawzall, and a 3 foot crowbar, I got the radiator out. I went to take the hoses off the condenser and I hear a hiss. Hmmm I thought the system had been sitting open for the last year. If it had been open that long about the only thing I could salvage would be the evaporator after a good flush. This changes things. So, how do I store things for safekeeping? I'm just starting to get into A/C work and don't know this yet.
Add to BarnOwl's Reputation
Old 05-26-2007, 01:51 PM   #2
Gerry Proctor
Gerry Proctor has a spectacular aura aboutGerry Proctor has a spectacular aura about
2008 Astra XR
2008 SKY Red Line
Default Re: What and How to Save off of A/C
Pull it and cap the ends. The only thing you can't save is the receiver/dryer.
Add to Gerry Proctor's Reputation
Rate the quality of this post and help Gerry Proctor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gerry Proctor is offline   Reply With Quote
Old 05-26-2007, 04:41 PM   #3
BarnOwl
BarnOwl's Avatar
2000 SW2
Ziploc bags and rubber bands okay for caps?
Old 05-26-2007, 04:53 PM   #4
Even paper towels rolled into a makeshift plug will do; all you want is to plug the ends off from any air/moisture/dirt entering until you decide what to do with the parts, even the receiver/filter/drier, especially if the system had a charge left and you heard the discharging of any remaining refrigerant.
Old 05-26-2007, 06:22 PM   #5
BarnOwl
BarnOwl's Avatar
2000 SW2
What I want to do is store the parts. I have two Saturns. Well, four if you count the car I'm parting out and the car that the engine from that car is going into. Sooner or later, I'm going to need a hose or a compressor or an evaporator or an expansion valve. The drier's cheap enough that I would want a new one if I was opening up a system anyway. I heard it discharging when I went to pull the fitting off the condenser. In fact I didn't take it off and I'm pretty sure it's going to continue discharging slowly all night.
Last question till I think of the next question, should I flush the evaporator and condenser before I put them up or before use?
Old 05-26-2007, 06:51 PM   #6
As long as they're intact, not cracked, bent, broken, and completely salvageable for use leave 'em as is till you use them then flush them and dry with compressed air prior to connecting. That way you're sure of a clean installation, even with the drier, as total evacuation for an hour or two will pull out any moisture. The drier is probably good since you have some charge still left that indicates the a/c system was still under pressure and not leaked out completely. I agree its cheap but it may be worth keeping. The key to a/c is a clean install, paying meticulous attention to the small details like how much and which oil, replacing the O-rings, knowing what oil is left in the system as in the compressor and draining it for replenishment with fresh oil, and last but not in the least the total evacuation of the system with an evacuation pump to rid the sealed system of any air and moisture. If things went right the vacuum gauge won't budge from absolute zero when the pump is turned off and the valves are closed. When no movement of the vacuum gauge needle is indicated for more than five, ten minutes then its safe to say that no leaks exist and refrigerant can be injected.
What is it that we are asking them to save? sixsigma General Saturn Discussion 32 12-15-2008 10:51 AM
Help me save a nice 92 SC GmG S-Series Tech 10 10-20-2005 07:18 AM
another way to save gas scarecrow0529 Mods and Performance 5 09-20-2005 09:23 PM
Save my Saturn Imprezatron S-Series General 18 03-22-2005 07:27 AM
