Old 08-12-2006, 05:58 PM   #3
92DualCam
92DualCam is on a distinguished road
1992 SL2
Default Re: water in the pasanger foot well
As SattyLite posted, most likely whats your up against. They are not fun to do, as you need to remove the carpet, and center console. I remove the BCM as it gives you a little more room to work with. Ive found it you remove all the screws in the HVAC box, you can get it down enough to goop it up with sealant it that upper corner where they tend it leak. Ive prob done 5 or 6 and havnt had one come back yet. Good luck!
92DualCam is offline   Reply With Quote
