Old 10-22-2000, 01:05 AM   #2
ssicarman
ssicarman's Avatar
Default
The door panel is a two piece panel. The area around the door release handle and grab handle is seperate from the main door panel. It is held on by four screws. One behind the tweeter cover, one behind the power door lock switch/hole cover, one behind the grab handle (front half comes off, careful they break a clip on the top very easily) and the fourth behind the triangular plastic cover for the mirror mount nuts. I go on the assumption you are talking about the front door panels. Good luck.
Add to ssicarman's Reputation
ssicarman is offline
