Old 03-26-2019, 10:12 AM   #3
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: High Beams Stay On
One side of headlamps are "hard-wired" to battery (thru fuses).
Possible causes of high beams staying on:
1. Ground side wire of lighting circuit intermittently shorted to ground or one of following keeping ground applied.
2. Sticky HEAD LAMP Relay (part of auto headlight system - I/P fuse block).
3. Lighting stalk problem - either high-beam activation or flash-to-pass.
4. Internal BCM problem.
