Old 12-30-2016, 12:22 AM   #1
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
Default Key stuck after radio install
I don't know if the radio has anything to do with it, but I just installed a new radio. I had it on acc so I could set everything up and make sure it works before I put the console back together
My battery died, enough to where I can't start my car but not too much to where my radio and some lights were still on
I couldn't get my key to turn to off. So I jumped it and it starts fine, but I still can't get it out of acc.
Not sure if it's something with the radio or what. I tied the wire that goes to the brake for videos when stopped into my ref ground, so maybe that's causing trouble?
Otherwise I wired everything else up with a harness, no cutting or anything
Any suggestions? I've heard of a lever or button but don't see one to release the key
Thanks
Add to JosephN79's Reputation
Rate the quality of this post and help JosephN79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JosephN79 is offline   Reply With Quote
