Old 07-17-2016, 12:23 PM   #1
Nick15-21
Nick15-21 is on a distinguished road
2005 ION-2 Sedan
Default Some Ideas I've Had
So as all us Saturn Ion Owners know, the Spare tire Cover in the trunk is that junky material board fiberglass stuff that will break apart with the littlest amount of force applied, so as Oxyhydro of this forum did, I plan on replacing that with plywood and cover it with the original carpeting. another idea i had was because i have a lot of wiring with my Emergency Lights just tucked under seats and things like that so i figured i might as well pull up the floor carpeting and run those wires under there and cut outlet holes for the wires leading to the light heads. also on the bumper there is that plastic divider that splits the bumper in two, which for the only reason i can see is for aesthetic purposes, I want to Cut that out and mount fog lights in there because my headlights are faded to hell. The Final mod i want to do is take some small pieces of plywood and possibly an acrylic sheet with hinges and a handle and make a battery box, because my battery seems to slide around if i take turns too fast. I'll update yall when i start this up. but if you have any other ideas or possible other alternatives to these let me know
Criminal Justice Major
Kid With No Car Knowledge
Add to Nick15-21's Reputation
Rate the quality of this post and help Nick15-21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nick15-21 is offline   Reply With Quote
