Old 07-28-2012, 02:08 PM   #4
n8rg8r
n8rg8r is on a distinguished road
Default Re: Reinstall '06 ION Driver Seat cushion
ok, i think i just figured out how to reconnect the seat cover/cushion on the driver and passenger seats in my ion.
you may notice a plastic "c" grooved bar hanging from the front of the cushion cover (there are two smaller ones on the backside of the seat connecting the back of the cushion to the seat frame).
if this "c" grooved bar is hanging loose at the front of your cushion cover and not connected, gently rub your hand under the seat to feel the frame (you can also lift the cushion up a little to see the seat frame)
the leading edge of the frame is a smoother steel piece with 3 bumps in it....
sit in the sit to apply pressure on the cushion, take both hands, grab the c bar at the edge of the seat cover...rotate the c bar "inside" so the groove is open upward...
push/pull the seat cover down as hard as you can to get it to slide over the edge of the seat frame (the hardest part i had with this was getting the foam out of the way to get the c bar over the flat edge of the seat frame)
those 3 bumps i mentioned....when you get the c bar over the seat frame edge, push hard to make the connection between the bar and the frame...it will click into place at those 3 points (bumps)
...and there ya be....it's reconnected...
if it doesn't click, either that c bar is damaged or you didn't squeeze that connection hard enough at those 3 points...
again, my hardest problem was manuevering the cushion out of the way to allow the c bar to meet the seat frame...
your cushion MAY be a little out of whack since the cover isn't sewn to the foam cushion....
mine is out a little, but not bad enough for me to worry about it...
if yours is bad, you can disconnect the back two c bars at the back of the seat and try and reposition the cover over the foam....
....hope that helps as it seemed to fix mine more or less...but, it came off once, so may again and probably has everything to do with how the person slides in and out of the seat....
i tried lowering and raising my seat, but that didn't seem to have much of a difference....
i did reinstall that clip while the seat was raised simply to allow my fingers enough room to rotate that clip and reattach it to the frame...
good luck!
Add to n8rg8r's Reputation
Rate the quality of this post and help n8rg8r reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
n8rg8r is offline   Reply With Quote
