Old 10-02-2019, 08:45 PM   #11
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Default Re: Aura remote start
Originally Posted by Tackl123 View Post
The make and model of the remote start Iím installing is ready remote and the model number is 24219B. It came with a immobilizer.
I'm not familiar with Ready Remote and they don't seem to provide manuals online without product registration.
Have you been to the Ready Remote site and registered yours for the wiring diagram.
https://www.readyremote.com/Registra...g=Expired+Code
Commando Alarms has this wiring information...
http://www.commandocaralarms.com/wir...Aura/1838.html
Here is a discussion from 12volt.com about installing a remote start on a 2007 Saturn Aura that might help. They say with the immobilizer bypass the starter wire is not required.
According to the diagram I sent:
The wire direct from the starter relay to the starter is purple.
The wire from the ECM to the starter relay coil is purple.white.
Putting 12 volts on either of these will crank the engine
I don't think you need to hook up the locks or alarm unless the alarm affects the immobilizer.
Hope this helps you out.
