Old 08-14-2013, 01:27 AM   #2
Default Re: 2006 Saturn Relay AC Drain ~ Saturated Floors Upfront
All a/c drain valves allowing condensate a way to drain away instead of pooling inside the HVAC box are usually by the firewall, below the four inlet/outlet lines for hot coolant and refrigerant. Its just a small rubber duck valve, allowing water to drain out and close to prevent insects from crawling in. These rubber valves are right angle designs. Just look carefully until you find it then gently poke the valve open with a pencil tip or finger - if the HVAC is retaining water then 'peeing' will occur.
