Old 01-24-2005, 01:46 PM   #3
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Default Re: Cranks for a while before starting...
This can be a fuel pump issue. My 97SC1 starts quickly at initial fire-up but will take some cranking to re-start when warmed up and shut off for a period.
The way to test for this is to put the key in the "run" position for a few seconds and then see if the engine starts quickly when you go to "crank".
Wolfman says it may run this way for a long time before the pump actually fails. IIRC a check valve tends to bleed off fuel pressure. I may do a preventive change-out over the summer when the car is back from college.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Murray is offline
