Old 08-05-2014, 01:15 PM   #16
ndifrischia is on a distinguished road
1997 SL1
Default Re: All Sorts of Problems!... i think
definitely have a valve cover leak, gonna take care of that today. P0300 i suspect from oil leaking down to the ICM. Hope the Timing cover isnt leaking also. Any culprit for the knock sensor code? Ive been running a higher octane than i should right now (done with that noise! back to the cheap stuff) and figured that may have been causing the sensor code... not sure though
Add to ndifrischia's Reputation
Rate the quality of this post and help ndifrischia reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ndifrischia is offline   Reply With Quote
