Thread: Blowout!!!
Old 11-12-2019, 02:14 AM   #8
Default Re: Blowout!!!
A 175/70R14 fits about perfect in place of the temp spare. Dropping to 65 from 70 would probably let it fit perfect; either one would last longer in-use then the temp spare.
I believe with the right offset (and inner wheel shape) even 13" wheels fit over the front calipers, some auto-x guys would run those tiny wheels & tires for better acceleration and less weight IIRC.
