Old 11-03-2019, 03:27 PM   #2
toggenburg
toggenburg's Avatar
Default Re: SL1 Automatic Issues
You said,
"I don't have problems when the temp gauge is at 1/4 or below. If the heater is on it never gets past that point so I can drive it around forever with no issues".
Please clarify 1 thing.
After you replaced the ECTS (verifying the connector was clean, and any wiring splice is soldered and shrink taped), so does the engine temp EVER go above 1/4 if the heat is OFF?
