Old 03-12-2014, 07:26 PM   #9
madpogue
1996 SW2
Default Re: Help! Motor Mounts replaced aaaaaand...
Originally Posted by sw201444 View Post
Took trans mount out. Replaced. Took top mount off. Replaced. Then I went under the car. Loosened the mount on pass side on frame then retightened hoping it would cause less vibrations but it didn't.
You need to loosen the _bracket_ that that dogbone strut attaches to. Two nuts on studs pointing downward. Then give the powertrain a little shake from above, to "re-seat" the bracket in its elongated holes, and re-tighten.
But ^^^^^ +1 dummo; what's up with the old mount? Looks like there was something out of place, rubbing against it. Maybe it's rubbing against the new mount now. Can you get a shot of the mount as it's installed now?
Add to madpogue's Reputation
