Old 11-17-2008, 11:06 AM   #2
FlintIonQC
FlintIonQC is on a distinguished road
2007 ION-3 Quad Coupe
Default Re: front end problem?
There is a TSB for the steering column i-shaft because it has a little play in it. All they will do is turn the i-shaft 180 degrees and see if that fixes the problem. If it is more than a tiny noise, just go to a place like Tuffy's and have them check out the front suspension to see if the tie rods or ball joints are shot.
FlintIonQC is offline   Reply With Quote
