Old 04-25-2006, 06:02 PM   #6
proton777
proton777 is on a distinguished road
Default Re: How To Remove Outter Door Panels & Lube locks etc - Step by Step 1997 SW2 w/ pictures
This is great. Very helpful, thanks. I have been trying to remove the outer driver door panel to see why my power window (93 SC-2) makes an awful noise as it gets to the bottom when opening.
So, two questions. On item #2, do you have any suggestions on getting to the Torx bolt that is at the bottom right corner of the door? It's the one under the hinge. I've tried everything to get that thing out without success. Now it is in pretty bad shape.
On item #3 about the pins that hold the handle in. When you say to "split the plastic push button", are you actually breaking them? They must be broken in order to be removed, and, thus, replaced?
Thanks in advance
Add to proton777's Reputation
Rate the quality of this post and help proton777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proton777 is offline   Reply With Quote
