Old 03-24-2017, 03:55 PM   #5
froggydogg
froggydogg is on a distinguished road
Default Re: 1996 SL2 questions
Any impact sensor to disable fuel pump operation isn't needed or necessary. Impact sensors are used in another area, airbags.
I am not a mechanic by any stretch, which is probably painfully obvious by now, but this is the main reason that brought me here.
The airbags inside her car had been deployed, and a few people were speculating that as soon as the airbags go off there is a safety fuel cut-off, in which the car can't be restarted, but I've never found mention of this in my research on Saturns, and know that some other makes/models could be started regardless of airbag deployment. I know for a fact that the '96 SL2 did not have an inertia switch, so I'm just trying to rule out the "airbag fuel cut-off" as well as any "impact-sensitive" fuel cut-off.
Add to froggydogg's Reputation
Rate the quality of this post and help froggydogg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
froggydogg is offline   Reply With Quote
