Old 09-12-2018, 09:09 AM   #2
Default Re: How to check if engine turns over
#s 4&5, use breaker bar and extension and you have to take off the wheel and splash shields. Take a set of large sockets as that pulley bolt can be different sizes. Turn CLOCKWISE ONLY.
If it is a manual turns put in 5th gear and just push it forward. If it moves the engine turned over. DO NOT PUT THE KEY IN THE ON POSITION AS IT MAY ACTUALLY START! Just put key in OFF position.
