Old 07-16-2005, 08:41 PM   #1
c5f8
c5f8 has a spectacular aura aboutc5f8 has a spectacular aura about
c5f8's Avatar
1997 SC1
2002 L-Series 2.2L Sedan
Default New Engine Install. Need new mounts?
Along with a new engine and new cradle (see gallery) I'm also installing new late model engine mounts (see attached photo). The bolt that goes into the small end of the dog bone fits extremely loose.
I measured the difference between the hole diameter and the bolt diameter using a dial caliper to be 0.130 inch. When the engine is bolted up, I can shake the engine and it moves substantially.
If I buy new mount inserts, do they sell different sizes of prothane motor mount inserts? Did Saturn change the bolt size after 97?
Add to c5f8's Reputation
Rate the quality of this post and help c5f8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
c5f8 is offline   Reply With Quote
