Old 08-03-2010, 04:36 PM   #15
KaraMac
KaraMac is on a distinguished road
1999 SL1
Default Re: Cleaning the EGR valve and other questions...
I took my throttle body apart, replace the TPS and the IACV, cleaned every surface again, made sure everything was on tight and tested the seal afterward with brake cleaner to look for vacuum leaks. The car is still idling high, now even higher than when I started this endeavor! There doesn't seem to be a vacuum leak because it stays high when I spray it.
I'm not sure where to start now! The car is running a lot better and more smoothly. Is there a way to reset the idle and that's what I'm missing? I let the car sit overnight with the battery unplugged and that didn't change anything either.
Hmm... Any suggestions would be spectacular.
Add to KaraMac's Reputation
Rate the quality of this post and help KaraMac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KaraMac is offline   Reply With Quote
