Old 08-02-2010, 04:28 PM   #14
KaraMac
KaraMac is on a distinguished road
1999 SL1
Default Re: Cleaning the EGR valve and other questions...
So I took everything apart and recleaned it. Tested my TPS with an Ohm meter and found out it's not so good anymore. Also the O ring around the IACV was all worn down and ripped, probably the reason why my idle was so high after I cleaned everything last time. I'm just getting replacements for the two because I'm sure it's needed and they aren't crazy expensive. I guess that's what my credit card is for .
Add to KaraMac's Reputation
Rate the quality of this post and help KaraMac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KaraMac is offline   Reply With Quote
