Old 08-19-2018, 11:07 AM   #6
chrisr123
chrisr123 is on a distinguished road
2007 VUE 3.5L
1991 SL2
Default Re: 2007 Vue Power Window - Driver's
Both led lights on the switch panel are working including the led for the driver's window switch. Could there still be a problem with the connector if the led lights are lit?
Originally Posted by atikovi View Post
I would test from the connector at the switch. See if you can make the motor work by putting power and ground to the appropriate wires. If it still doesn't work, check continuity and shorts to ground between the switch connector and motor connector.
Add to chrisr123's Reputation
Rate the quality of this post and help chrisr123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chrisr123 is offline   Reply With Quote
