Old 11-21-2014, 12:53 AM   #5
satlite440
2001 SL2
Default Re: special policy coveage for p/s pump&steering gear houseing
at this moment the gear assembly is not covered...the upper housing where the spool control is.is covered....if a steering gear is replace an alignment is to be done for toe set under warrenty...recommended for customer pay...
