Old 11-24-2017, 08:08 PM   #1
ldollahan
ldollahan is on a distinguished road
2002 SL1
Default Rear brake line replacement 2002 SL1
So one of the lines rusted through & popped a hole the other day coming home from work when I had to slam on the brakes to avoid a collision, (which I did avoid!).
I got everything unhooked today, but haven't pulled out the lines yet, ran out of daylight.
I go two new rubber lines to go to the wheels, & a roll of Brake Tubing - Universal Steel Hydraulic 3/16" from Napa.
Also got the nuts & they loaned me a flare kit.
My questions are - is one roll of 25' enough for both rear lines to the MC,
and the lines that are on there at about a foot from the end where they attach to the rubber lines at the back, the steel lines have what looks like a spring/wire wrapped around the outside of the line. The new line I have does not have that?
I've seen some threads on here that recommend the Nicopp, I can get that from Autozone here although it's more $. Would I be better off with that? Easier to bend?
Add to ldollahan's Reputation
Rate the quality of this post and help ldollahan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ldollahan is offline   Reply With Quote
