Old 08-20-2005, 05:54 PM   #10
Jldet5
Jldet5 is on a distinguished road
2004 VUE 3.5L
Default Re: HOW TO: 3.5 Auto Trans Fluid Change
Originally Posted by ssicarman
You will not get a complete trans fluid change that way either as the oil is pumped through the cooler lines by the trans oil pump and it will stop pumping when the fluid gets low. Not to mention the potential damage of running the trans with way to low fluid.
You use the cooler line to draw in the fluid at the same rate from what I recall.
Add to Jldet5's Reputation
Rate the quality of this post and help Jldet5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jldet5 is offline   Reply With Quote
