Old 06-14-2017, 07:29 AM   #26
maschinenbauer
maschinenbauer will become famous soon enough
maschinenbauer's Avatar
2008 Astra XE
Default Re: Ignition switch problems
Sticky clutch switch sounds like a good explanation. I prefer starting without the clutch anyway, except for those mornings when I forget to take it out of gear and it lurches forward a bit
It's supposedly better for the thrust bearings in the engine, since the clutch puts an axial load on the crank when the engine is cold and less lubricated. Probably doesn't make much of a difference though.
'08 Astra XE 5-speed
'72 Chevrolet El Camino
'31 Ford Model A pickup
Add to maschinenbauer's Reputation
Rate the quality of this post and help maschinenbauer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
maschinenbauer is offline   Reply With Quote
