Old 07-11-2012, 07:17 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2004 Saturn Vue radio stopped working
I would check the BATTERY 40A fuse in the underhood fuse block.
If your Vue came with a factory-installed subwoofer, you will also have a fuse labeled PREM AUD 20A at the underhood fuse block.
There are two fuses in the instrument panel fuse block. One is RADIO 10A and the other is RADIO (IGN) 10A.
If all fuses check out fine, the radio is probably defunct. You can take it out and double-check the plug going to it just to be sure though.
Replacements can be found on ebay for under $50 unless you have an MP3-capable six-disc radio which goes for around $100.
2007 Ion 2 Quad Coupe 5-speed manual 182K miles
2007 Chevy Equinox LT 194K miles
2018 Chrysler Pacifica Touring L 41K miles
Add to ruley73's Reputation
