Old 11-07-2017, 05:42 PM   #4
cheap one
cheap one is on a distinguished road
Default Re: catalytic converter for standard transmission
Originally Posted by ruley73 View Post
Are you aware that the flex pipe can be replaced separately? You can buy a decent quality replacement flexpipe for under $50 from eBay or Amazon. An exhaust shop will need to cut the old one off and weld the new part on.
I wouldn't replace the cat con unless you have more than 200K miles on the car. Even then, I'd probably let it ride unless you know it's clogged.
Thanks for reply - This may be the way I go even though I just turned over the 200k mark. This is the first car I bought brand new that hit 100k let alone 200k miles!
Add to cheap one's Reputation
Rate the quality of this post and help cheap one reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cheap one is offline   Reply With Quote
